Motorradführerschein der Klasse A
  • Bibbi
  • 11. April 2024 um 14:04
    Thread Summary
    The discussion centers on a motorbike license question (class A) about the minimum distance from a crest when starting to overtake a truck ahead at 70 km/h while the rider is at 100 km/h on a road outside built-up areas. The thread shows a lively mix of reasoning, practical cautions, and debate about the correct number.
    Key viewpoints and conclusions
    • The most commonly debated figure is 800 m. Several posts argue this is the “gesuchte Antwort” for the exam, while others question the exam wording and realism.
    • Other participants suggest different numbers (around 400 m or 200 m), often arguing that the exact distance depends on factors like vehicle length, acceleration, and whether Siegeschichten gelten. This reflects disagreement about a one-size-fits-all answer.
    • A practical takeaway in the thread is that overtaking requires significantly more space than beginners expect. Several posters emphasize that you should not overtake if the crest is unclear or if there isn’t ample margin for error.
    • Several users advocate using a teaching method called the “Kontrillrechnung” (counter-check calculation) or rough estimates based on speeds and lengths (e.g., assuming a typical LKW length around 15 m, and using relative speeds). These methods are presented as safe-learning tools rather than exact real-world prescriptions.
    • The discussion references learning materials and sources:
    • Some participants point to the Führerschein-Bestehen explanations and to a Degner book for how the calculation is taught.
    • Leitpfosten and simple distance estimation (e.g., 50 m between posts) are suggested as rough real-world cues, though not as exam answers.
    • Open questions and disagreements:
    • There is no universally accepted official distance cited in the thread beyond individual claims; several participants note ambiguity in exam questions and in how the numbers are presented (units and conditions).
    • Real-world applicability versus exam framing: many participants view the exercise as a learning aid to sensitize about space needs, not a perfect instruction for every overtaking scenario.
    • Some participants warn that the group dynamics and peer influence can affect how people approach overtaking decisions in practice.
    Notable points for readers
    • If you’re studying for the exam, be aware that 800 m is frequently cited in this thread as the expected answer, but be prepared for other interpretations or uncertainties in official wording.
    • In practice, rely on a broad safety margin and avoid overtaking near crests or when visibility is compromised; use the conceptual idea of “more space than you think” rather than a fixed rule.
    • Use the cited study aids (Kontrillrechnung, Anhalteweg concepts, and the Degner/learn-to-drive materials) to understand the underlying reasoning, while recognizing that real-world conditions will vary.
    Zuletzt erstellt: 7. März 2026 um 13:32 Hinweis: KI kann Fehler machen. Die Zusammenfassung kann unvollständig oder nicht korrekt sein. Zwischenzeitlich können zudem neuere Antworten vorliegen, die den Inhalt beeinflussen würden. Es kann daher später eine aktualisierte Neuzusammenfassung folgen. Bitte lies zur Sicherheit das Thema vollständig.
  • Bibbi
    Da ich gerade den großen Schein mache, tauchen für mich doch merkwürdige Fragen auf :S
    Wer rechnet solche Fragen vor einem Überholvorgang mit 100 km/h aus? 🙈
    Sie fahren 100 km/h auf einer Straße außerhalb geschlossener Ortschaften. Vor Ihnen fährt ein Lkw mit 70 km/h. Wie weit müssen Sie bei Beginn eines Überholvorgangs von einer Straßenkuppe mindestens noch entfernt sein?
    • 400
    • 800
    • 200
    Ich habe mir nur die Antwort gemerkt 8o
    Roadrunner72
    • 11. April 2024 um 14:51
    Das mußt du bei der Polizeikontrolle wissen! 😂🥴
    Spaß. ABER: Die Frage hat einen sinnvollen Hintergrund!
    Warum? Überholen wirst du später zig Mal. Und auch, wenn du dann leicht über 100 km/h fahren wirst, hast du einen nicht unerheblichen Überholweg!
    Quint Essenz: Wenn du überholst, brauchst du Platz. Und das muß dir bewusst sein! Wenn dir hinter der Kuppe einer mit 100 km/h entgegenkommt, siehst du bei zu wenig Platz verflucht alt aus - wenn du dann noch aussiehst.
    Dir viel Erfolg bei deinem Schein! ;)
  • Bibbi
    • 11. April 2024 um 16:41
    Das ist definitiv richtig 👍
    Die Frage kommt mir nur so vor, als ob ich vor dem überholen noch rechnen soll 😏
    ich bin eine eher defensive Fahrerin und wenn ich mal mit dem Auto überhole , rechne ich keine Faustformeln aus 😉
    Danke dir ✊🏻
    Roadrunner72
    • 11. April 2024 um 16:54
    Nö, du sollst dir nur im Klaren darüber sein, dass er länger ist, als du denkst. Also der Überholweg. ;)
    Ich hab schon Pferde vor der Apotheke ko... sich oral entrümpeln sehen.
    Gerade die Gruppendynamik ist nicht zu unterschätzen. Ich habs schon so oft gehabt, dass Leute auf gedeih und verderb an der Gruppe dranbleiben wollen, dass sie blind überholt haben. Da wirds einem Angst und Bange.
    Wenn du mit Hirn bei der Sache bist, ist das prima. Dann brauchste nur die Zahl für die Prüfung behalten und gut ist ;) 👍
    • 11. April 2024 um 17:36
    ...und welche Zahl isses nu?
    Kommt gefühlt doch auch auf die Motorleistung / Beschleunigungsvermögen an, oder? :/
  • TESOMA
    • 11. April 2024 um 17:58
    Ist doch egal!
    Wichtig ist nur die Zahl für die Prüfung!!
    • 11. April 2024 um 18:09
    Die Frage ist Mumpitz, meiner bescheidenen Meinung nach. Wer kann schon, an einem LKW vorbei schauend, die Länge der Sichtweite realistisch abschätzen und dann soll er oder sie noch Berechungen anstellen?
    Mit meiner Tracer überhole ich gefahrlos an Stellen, wo ich mit der XT hinter dem LKW bleibe. Rein aus Überlebensinstinkt.
    Da werden Fragen für eine Prüfung an einem grünen Tisch ausgearbeitet von Leuten, die es besser sein ließen.
    Viel Erfolg , Bibbi.
  • FZxNobby
    • 11. April 2024 um 18:14
    800?
    Norbert
    kaulebeen
    • 11. April 2024 um 18:19
    …der Überholweg sind ca. 400 m, wenn ich mich nicht irre…
  • Froggy
    • 11. April 2024 um 18:22
    Ganz schlechte Antwort bei der Prüfung!
    In der Frage steht, dass man selbst außerhalb der geschlossenen Ortschaft 100 km/h fährt. Da gibts nichts zu beschleunigen!
  • Dieses Thema enthält 29 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
